Bayliner3.0
- Feb 13, 2024
- 61
If it was in my ski locker would have no issue using it. Having just bought it I would send it back unless you are in a time pinchI got this for pulling a skier, kneeboard, wakeboard.
It is a 4 piece trick handle airhead wakeboard rope. It came like this damaged. Not sure how it happened. Rats at amazon lol..
Thanks for your opinion. I was wondering if others think it is OK to use, so you are +1.If it was in my ski locker would have no issue using it. Having just bought it I would send it back unless you are in a time pinch
Well no pros here, but it is listed as nylon pre stretched, low stretch rope. As opposed to high stretch nylon lol… Yeah maybe the next on I will spring for something better Poly E or Dyneema.Never use Nylon for a Ski Rope, far too stretchy.
Yep, 2 skis and a kneeboard. We will see if anyone gets good, then might get a slalom, or wakeboard. I was reading about pressure on the rope and yeah we probably wont be reaching any limits.If you are a rookie, that probably means you are skiing with 2 skis instead of slalom skiing, and not running a slalom course, or barefoot skiing. Those types of skiing put a bit more pressure on a rope, but even if the rope breaks, it is generally not a major disaster. So, with that said, I would ski with it and get maybe a year or more out of it. Then when I was ready to move on to a better rope, cut the better pieces out of it and use it for deck lines or fender ropes.
You might be right, Airhead has their dyneema line listed as nylon on Amazon too.. Material Field shows Nylon, description shows Dyneema.Use a lighter and melt the fray, then go skiing.
When it breaks, make another knot/eye splice
That appears to be polypropylene line and not nylon
Wow, ok that may have sold me. The thinner the rope the easier to cut in too so hmmm -2 for dyneema...Always use Poly for any kind of toy, it floats, and you want it to float
I would not use dyneema with toys, main reason is it's stronger then steel. While poly may not break if it gets wrapped around a limb, it has a better chance of not cutting it off. Case in point, gal got ankle tangled up in ski rope on watercraft. She got a real nasty burn, dyneema would have probably taken the foot off
