HI Guys been while since I was here, weather is warmer and I want to tackle that motor,
Which motor you ask? Scroll up
here is a list of the parts I need
Water pump kit. impeller gaskets etc do not need the housing
The two gaskets on the power head, one is under the panel that is around the plugs, the other is under the panel on the side of the motor
Upper motor mounts, I think mine are shot
I have to pull the powerhead to change the gasket or gaskets between the head and the mid leg, what gaskets are these called, gotta pull the powerhead to fix leaking gasket
two carb overhaul kits
