I pulled my lower unit(hydroelectric)on my 3 cyl. johnson (1971-65hp?) as I had no forward gear, just reverse and nuetral. The solenoids and wiring check out fine as does the plunger. I found that if I lift on the drive shaft while turning the prop shaft will turn but you can stop it with your hand. Without lifting driveshaft i get a ratchety feeling when turning. I want to disassemble it but have no manual for this unknown motor. I have removed all the bolts but need help on removing the bearing carrier and driveshaft. Do i need a puller? I have a lot of tools and auto experience but don't want to wreck this unit. Any thoughts or info is appreciated.
