Hello,
I have a 1986 14' Sears Gamefisher Tri-Hull fiberglass or FRP. The boat was kept in the water and not taken care of from what I can tell. The gel coat has completely worn away inside and out, there are fibers poking through so much it looks like it was painted with sparkles and you get the itchies after your in it.
I read as many posts as I could find about bottom paint, fiberglass paint and topside paint, but the last post was over a year ago and only one of them really was along the same lines as my problem. (http://forums.iboats.com/showthread.php?t=387069&page=1)
I don't have alot of money to get the boat redone professionally, I asked a few shops around me and was given numbers in the thousands, I only paid 500 for the boat.
Are there any new products out that I can use to paint the entire hull with? Inside and out? Should I put a sealer on first or will the paint do that for me? As I said the gel coat is pretty much gone, so I think I have to seal it before I paint it. The boat will be trailered all the time so I need something hard so it doesn't rub off on the bunks.
I want the boat to look good, but I have to do it with a brush and roller, can't spray it and I don't have a lot of extra money around to buy super expensive products with.
Any ideas are appreciated.
Thank,
Anthony
Thank,
Anthony
