lots of boats
- Jul 28, 2008
- 116
When hp rating was standardized by dyno testing at the prop shaft what were the parameters, if any, other than rpm of the engine? What RPM are they tested at and are all the on board systems such alternator load, or air pump load somehow calculated into the hp rating so that when you have motors with electronic or other injection systems, should they be producing the same hp as a carburated engine?
