suparslinc
- Oct 23, 2007
- 29
I recently experienced a blowout on my trailer. The tires were I believe original, so probably close to 20 years old if thats possible, they were pretty dry rotted and a rear tire blew after about 11 miles of low speed driving.
Got a spare on, and stopped on the way home after about 5 miles. The other rear tires was pretty warm (its a tandem), but I also believe more of the boats weight is on the back two tires.
Got four new tires. The guy at the tire shop showed me that one of the wheels had quite a bit of grease on it; he said it indicated a failed bearing. Now I don't believe this to be a true tell because the bearings are not sealed and have bearing buddies. However, when I got home, I spun the hub on the back wheel and it did not spin as freely as the front. If I kicked it the hub would spin for about another 1/4 turn at best. But, it has drum brakes on the back, so I think it's possible the brakes are just tight or corroded.
Given that, is it possible for a hub to heat up so much in 11 low-speed miles that the tire would lose cohesion? I don't think the bearings are bad but I don't want another blow out either.
Boat and trailer weight ~3700 pounds with 4 C rated trailer tires.
