Hello Everybody,
I have a 22yr old Baja and want to check for water logged foam under the deck. The deck has a panel down the center of the floor that unscrews and gains access to the fuel tank. You can't see anything around the sides of the tank it is a tight fit in there.
Is it usually possible to take up one side of the deck without destroying it?
I can't find any screws to remove down the sides. Is the floor usually glassed into the sides of the hull?
Thanks.
Thanks.
