My 1984 Sea Ray has a standard Commander with the neutral push button at the base, trailer button, then the trim button. At the top, the handle has a trigger to pull in to take it out of neutral. I can not find any diagrams that show how to tighten the assembly. The throttle lever is loose, but works fine. I see a screw at the bottom of the lever that goes up and in. Thanks for your help.
