Re: How to properly use OMC Gel Seal to assemble my 1991 40 hp johnson crank and cyl
We would use our finger tips to tap the sealent,kinda puts little lifts to the stuff,we would tap it around the whole sealing surface,if done right you can control the amount by the color,you will understand by trying it,if you use too little ,it will be a very lite pink,too much brings it to the color of a dab of it,you kinda want somewhere in between,this process insures total coverage ,and,I (we)never had an issue.I worked in a powerhead rebuild shop for years.
