chevyww1936
- Apr 25, 2013
- 2
My father and I just bought a 2005 Yamaha 2-stroke 90HP Outboard. I has been sitting in a guys back yard for over 2 years without being started, but it is in amazing condition, there isn't even any paint worn off the skeg yet. Anyways, on the ride home i noticed it was leaking a lot of 2-stroke oil down the outside of the motor case so i popped to cowling off and come to find out the oil reservoir was cracked and leaking all the oil out. I have gone through all the carbs, got new fuel filter, new fuel lines and pump and hose to the tank. I have always owned motors where i mixed my own 2-stroke oil and i would like to do the same again, I know when i removed the oil injection on my yamaha four wheeler there was a kit with a block off plate and rubber nipple to close off an opening on a carb. Is there a kit out there like this that i can use? or can anyone walk me though the process so that i don't run into any problems? I know there is a sensor wired in so if it is not removed correctly its possible it could prevent me from starting the motor. Thanks, any help would be greatly appreciated.
