sornstein2
- Mar 18, 2014
- 5
Can anyone tell me the proper procedure to adjust the shift linkage on a 6hp Tohatsu. I have the shop manual, but it's no help.
Hi, have the same problem. 2003 4 stroke with the rubber grommet in the middle leg. I think the prior owner replaced the impeller and (lost the grommet) and must not have synced the linkage. Only goes into neutral and reverse. Is the fix you suggested done @ the grommet hole?
" placing the LU cam rod in R, the shift lever in R, and snugging down the rod coupler..."
Thanks
