Re: How fast does your 4.3L V6 push your boat?
An interesting exercise is to calcualte the theoretical top speed of your boat (regardless of weight or HP). Take your max RPM, and divide it by the Gear ratio of the outdrive, this will give you the revolutions per minture your prop is turning. Then multiply this by the pitch of your prop, this will give you how many inches per minute you are traveling. Convert inches per minute to miles per hour and you will have the theoritcal top speed. I say theoretical because you will have prop slippage (you won't get the full pitch lenght in travel per prop revolution). Example calcualtion from my boat ...
4800 RPM / 1.62 Gear ratio = 2963 RPM at the prop
2963prop RPM X 19 inch prop pitch = 56296 Inches/minute (woo hoo baby)
56296 Inch/Minute = 53 Miles/hr
My Gps measures 49 Mph so I guess that pretty good prop performance.
My boat is a Chaparral 280 SSi with twin 5.0l EFI, but you can see from the calcualtions that it's not relevant. Speed will be dictated by RPM, Prop pitch (of course weight boat size etc dictate the HP and prop pitch to reach full RPM)
