Re: How do you keep your batteries covered?
http://www.iboats.com/Marine-Batter...2137220--**********.315706543--view_id.374310
You are correct, these need to be covered as well. Not only that, but that wiring job is not to ABYC standards. (I will include a caveat that I cannot tell which way it up in the photo, but assume that the wording on the batery switch is indicating that the postive bus bar and switch are mounted on a bulkhead wall and up in the picture is up in the real world).
Notice how the postive cable from the swtich to the bus bar on the left goes up and then down? There is no drip loop here. so if water gets on the cable in any way, it will run along the cable and straight into the switch and/or positive bus bar. All cables should be running UP to the connection, so water will run down the cable and away from the connector, switch, or bus bar. the remaining positives and all but one negative all look correct. The black negative coming from the top left of the picture really should have been run under the bus bar and switch and up to the negative bus bar.
You would need to run any horizontal runs or runs coming from above, down past the bus bar or switch, then back up to the connection.
Schrew,
Can you point out to me in ABYC Section E-11 where drip loops are a requirement?
Schrew,
ABYC Section E-11...drip loops...requirement...
