How do you change the upper water tube grommet? 1987 Evinrude 88 SPL
I have a 1987 Evinrude 88 SPL. Picked up a plastic bag over the water inlet when cruising. Stopped just before major damage but lower rubber exhaust housing seal started to burn through. Replaced everything at the bottom end including water pump and when running notice some water running out at top front of mid section during fast idle. Need to replace the upper rubber water tube grommet at the top of the mid section. What is the procedure? Can it be done without removing the powerhead? Not sure if the top seal of the inner exhaust housing needs to be replaced. Thanks
Joe Reeves
Re: How do you change the upper water tube grommet? 1987 Evinrude 88 SPL
The water tubes are attached to the powerhead adapter plate... hellava job!
Remove the lower unit... remove the powerhead... remove the adapter plate assembly... now you can remove the water tube and replace the grommet.
fireman57
Not only welcome to iboats but to working on them too!
gm280
Are you sure it is a 1987 88 special? Because I haven't found a listing for such a engine from Evinrude in 87...
Joe Reeves
I just checked my OMC Model Guide book. It lists a 88hp for 1987 as model #88MSLCU .
gm280
Thanks Joe R, I went to the usual parts section and there was no listing for an 88HP special in 1987 year. But you live and learn...my mistake... :facepalm:
Joe Reeves
You should see the misteakes I make! :) :)
I don't know if that 88 is special or not but it's there.
Hey guys,
Thanks for all the replies.
I've never pulled a powerhead. Can't wait..... Is it a big job?
Does anyone have instructions or a rough guide?
Thanks again,
Fred
BTW, it is an 88 SPL Model # E88MSLCUS
Not sure what is so special but was told it was basically a 90hp.
Bob_VT
Hey guys,
Thanks again,
Fred
Get a manual...... a proper shop manual that specifically covers your motor. The investment in the manual will be well worth it in the long run for maintenance. https://www.outboardbooks.com/
The OEM manual is the "rough guide"
10-4. Just found a Seloc Manual for 73-91. Should have enough info in there to get started.
fireman57
OEM beats the snot out of Seloc or Haynes. Get the real one, you won't regret it.
