JoeW
- Nov 8, 2003
- 664
Apparently I have a bad oil level float in the plastic resevoir of my 1987 100 hp Mercury o/b (2+2). How do I know this? I have a constant beep-beep-beep when the ignition switch is in the "on" position. I know the engine is getting oil. I can make the beeping stop by inserting a telescoping magnet into the oil resevoir. My thinking is that this eleminates the possibility of a bad warning module, or low voltage to the warning module. I say this to invite criticism, if any, to my logic.
My question is this. Now that I have the oil resevoir off of the motor, how do I remove the float from the resevoir? Should I try to just replace the entire resevoir?
Thanks in advance.
Thanks in advance.
