Re: hot water tank
Size according to the size of your family. My 40 gallon has had a work out when all the kids were home. Nine of us in total. Sometimes we would run out, but the recovery time was about a half hour.<br /><br />My opinion is the larger tank equals a larger bill. Why heat that much water when you only need half of what is in the tank. Lots of pro and con on the subject.<br /><br />If you have copper plumbing, just make sure you install new die-elelctric unions on the tank. This helps prevent electrolysis which will pit you lines creating leaks. Sorta what the anode does that was mentioned in a previous post.<br /><br />Since it only my wife and I at home now, I have mine on a timer. It comes on in the morning at 5am and off at 6:30am, and back on at 4pm and off at 8pm. This cut our electric bill by about $50 to $70 a month.<br /><br />In this area RUUD, and White-Rogers is a big seller. Good Luck
