Hi guys
I have Honda BF8A. Problem is it goes for hrs and sometimes days then cuts out. It can cut out when going hard or trolling. It will start right away and idle no problem every time. Carb is full of fuel. Fuel system has been checked thoroughly.....all seems in order.
After it cuts out and you start it.... it stalls immediately as you forward or reverse it. Six or seven repeats of this will see it take off until it repeats the scenario 5mins or 5hrs later.All coils are within resistance values and continuity has been checked on every wire around the engine. Kill switches and dead man switch have been isolated when running and it makes no difference.
Going round engine I have only been able to find that silicone rectifier for charge circuit is dud........and ignition timing was out maybe 1-2 deg. I swapped out CDI coil with HT leads for a S/H one.....symptoms are the same.
Have tried primer bulbs and different tanks Exhaust is not rotted and engine does the same with hood on or off. sSparkplugs are good colour and mixture set up per W/M. Engine is long shaft with tiller and all CDI ign.
Any ideas appreciated
Alex
Alex
