Been a while for me as I have been without a boat for a few years (bought a dang camper). Anyhow, I bought a 1981 Wellcraft 255 Suncruiser with a MCM 260 5.7 (sn 5953535). I have replaced all the normal tune up parts, and even went as far as replacing carb with reman Qjet from a place in Florida I have used before with great success. Replaced anti siphon valve as well and cleaned p/u tube. Fuel is a little old and not shiny clean like it should be, but after all this that I have done, i took it out to run it. I eased the throttle up and she almost got on plane, but kinda stumbled, ran real rough (not a missing feel, but rather a “choked out” feel) and died when I went to neutral. Opened the “hood” and water was all over the top of the engine. After further review, i found that the port side upper exhaust boot (between elbow and y pipe I’m assuming) has a small crack in it and it is pointed right directly toward carb and dizzy. Now...dizzy cap is new with fresh gasket under it but not ruling it out. But does it sound like to yous guys that she was spraying like a sprinkler head under the hood when I throttled up and just drowned the motor through the carb??
Reason I did the tune up was due to the stumbling/rough running problem. After test drive, acted the same. Swapped carb and did the anti siphon valve swap and cleaned the tube...then the water spraying issue started.
