I have a 1983 75 HP Evinrude. The powerhead was rebuilt three years ago when I purchased the boat and a used head was installed. Since then I have used the boat apprioximately 2-4 times a month pretty much all year around. Always flushed with freshwater after running. Recently the motor was sluggish and bogging on initial acceleration and stalling occasionally when going in gear. I also noticed that the top speed was down 5 knots or so (tach does not work). I pulled the plugs and noticed water on the #2 cylinder (middle cylinder). I ran a compression test, #1 120 psi, #2 90 psi, #3 120 psi. I took it back to the mechanic who did the rebuild and he said there was a hole in my cylinder head and it would need to be replaced.
My questions, what could of caused this and is his solution ok? That is should I/he be searching for a cause? Water pump works fine but is 3 years old. Engine did not overheat as far as I know, that is no alarms, etc.
Any help would be appreciated.
