Hit the Breakaway Actuator and Damaged the Surge Brakes
PHorgan
I backed my truck over the breakaway actuator on my tandem trailer (please, don't ask!). When I pulled it off I yanked the "handle" forward and seemed to have partially activated the trailer brakes. The trailer brakes are dragging on the disk. The brakes aren't fully engaged though. I tried to drain the brake lines to release the brake but it didn't work. Any advice on how to fix this? I've never messed with a hydraulic actuator before.
dingbat
Re: Hit the Breakaway Actuator and Damaged the Surge Brakes
Follow the breakaway cable to the point where it enters the actuator. There is a clip that needs to be "adjusted" to release the braeakway feature.
If all else fails, read the manual
Silverbullet555
x2. UFP actuators have access on the bottom and there is a plate that you just have to move and it will release the cylinder. Others are similar.
What kind of actuator do you have?
PHorgan
No manual for my Performance trailer (out of business I believe) with the Titan actuator. I'll look for the clip and/or the plate and try to release. Thanks gents.
Thalasso
Just google the titan model number and download manual.Titan is still in buisness
PHorgan
That worked guys. I popped the clip and reset the breakaway lever. Thanks!
