I have a 1970 40 HP Johnson and have a question on the high speed orifice. I do not have a high speed needle on the bottom of the carb. It is just a, what I am reading, a drain plug with the high speed orifice behind it. I can take it out and it appears to be clean. But my questions are:
1. If this is a drain plug shouldn't the fuel drain out of the bowl when I remove both the orifice and drain plug off? I am thinking that this is how I am to drain the fuel out of the bowl at the end of the year. Is there some trick for getting it out because mine does not drain anything out but a couple of dribbles.
2. When putting the high speed orifice back in do I just screw it all the way down until it stops or do I back it back out a certain amount after seating it?
Thanks for any help.
