special_kaye
- Apr 5, 2009
- 170
Okay folks, first off, I didn't do this but I'm going to make it right.
It appears I have a cast-in-place transom repair that has gone south. I knew what I had going in so it's no surprise to me but some folks might have not seen this.
The PO appears to have added a layer or two of some type of fiberglass in the splash well and about the same quality of work in the bilge.
This appears it'll be my next major project. I'm going to buy a new-to-me motor on Saturday and wouldn't want to use it for an anchor. So, I'll pick up the new motor but I won't hang it until I get this transom whipped back into shape.
I can't say for sure that miss-use and abuse didn't play a part in the damage done. I do know that this appears to be a cast-in-place repair. I do know that the PO's work ethics WERE NOT up to my standards. I do know that this motor was never supported while trailering and weighs in close to 500lbs. And I do know I'll fix it as best I can before hanging my new motor.
Feel free to chime in with your thoughts. I look forward to hearing all you have to say. Plus, I'm not sure I'm going to keep the set-back bracket. It's not a true jack plate, it's a set and forget type setback. Is it worth keeping?
