I have a new to me bayliner and would like to get a little better performance out of it, namely it is a bit slow and bogs down a bit when towing a heavy tube or a boarder is pulling hard on the rope.
It came with 2 props (a 14" 19P and a 14" 17P 3-blades) I live and play at 6750ft elevation so the smaller 17P pitch is the only prop I have used. It still does not get all the way up to the 4800-5000 rpm range, only about 4400 and 27mph (gps and gauge agree).
1) I would like better power for tubing and wakeboarding and a higher top-end speed would be nice too
2) Current prop: volvo aluminum
3) Current prop: 14" 17P
4) Wide open throttle: 4400RPM and speed: 27mph
5) Engine: volvo AQ125A /drive make: 270 1985 115hp
6) Bayliner Capri 195 bowrider, 1985
I'm thinking of a solas amita 4 blade prop. Should I change pitch to 15P? and is SS really worth all that money?
Thanks for any help.
