I have a Bayliner Capri with the Volvo Penta AQ 125 and 270 outdrive.
I just bought it after it had been sitting for over 7 years.
I got it running after draining the gas, charging the old Die Hard, and installing new plugs. I .sed mouse ears with a water hose. No water comes out of the exhaust. I opened the raw water cap above the heat exchanger and saw no water. I put water into the exchanger and still nothing comes out of the exhaust. I then pulled the cover for the raw water pump that drives off the timing belt. The water I put into the exchanger came out.
Is ther another water pump in the outdrive leg?
Sorry, I have no manual.
TNX Tom
TNX Tom
