I started pulling apart a 1963 650 and noticed the lower unit did not match up to the middle casing. It would not shift in and out of gear while attached but with a 1/4 inch gap while lowering the unit it shifted fine. I don't think this is the original LU and would like help identifying it. The only numbers I found are in the casting inside by the trim tab bolt hole, it is 6123-6051. Also is there a web sight that has this info? Thanks.
