Re: Help fixing my speedo
See whatcha get for seeking on-line advice from a bunch of idiots?!? Big ol' cooked hole in yer oudrive! Funny.<br /><br />Anywho...I'm quite serious about the muriatic acid. It's dirt cheap, and used heavily in the industry to get hard water deposits off of the outside of the boat and outdrive, so I frankly wouldn't hesitate to use a dropper to squirt some into the top hole to see if it starts smokin' and fumin'. I've done it before and I'll generaly dilute about 2 parts water to 1 part acid and it works nicely for wiping clean a crusty old boat. So if you squirt some in the hole and see a reaction taking place, that's good because you know it's working. Let it cook for a while and then hose it out with plenty of fresh water to neutralize the acid. If it were mine, I wouldn't hesitate to try it IF you think maybe the problem is hard water deposit buildup. If it's something else, the acid may not even react with whatever it is and you'll gain no ground. Either way, I really don't think it can hurt a thing (famous last words,right?!) after all, there's no moving parts in that passageway, it's just a simple pipeline.<br /><br />I'd also strongly suggest you post this same question in the "Mercruiser repair" thread of this forum. Actual boat techs frequent that specialized forum more frequently than this general boat section, and I'm sure this is not an uncommon issue that someone over there can help you with. Hopefully that helps.
