Re: How much should it cost me for this repair?
I can't comment on the head gasket, but I had the small starter bolt break on my Mercruiser 140. A friend of mine with better mechanical skills than me came over with a left-hand drill bit, a right angle drill and an easy-out set. Working with a mirror and drop light, he was able to drill into the broken off bolt piece and use an easy out to remove it in about an hour total. But I would say there are too many variables to really estimate it. As Don said, if there isn't enough room to get in there, the engine may have to be pulled to get at that broken bolt. My bolt piece was not loose enough to be spun out by the left-hand drill bit, but a piece that was loose enough might spin out in 10 minutes. I would also use the starter-to-block mounting bracket or rig one up if the new starter is the permanent magnet, smaller type. And as Don said, you have to use the two starter bolts.
edit: btw, I had several starters fail because they were getting wet. The mounting may not be causing your starter failures (but you do need both bolts).
