I have a 1964 Evinrude lightwin 3 HP outboard, just replaced the head gasket and the head bolts keep coming loose and causing the motor to stall and then not re-start. I torqued them to 80 inch lbs start the motor and it will run good for about 5 minutes then stall, I re-torque them and it starts right up, any solutions to this problem?? Maybe loctite, maybe lock washers????
