Re: Head bolt snap-o-phobi***
An update for those who are in my same situation.<br /><br />With all the great tips from you all, I ended up going to NAPA and got a 14mm spark plug re-thread kit (35 clams). It came w/ 4 threaded "sleeves" of diff. lengths, a ream/tap & locking compound.<br /><br />I did not fill the cylinder w/ grease, but I did slather the tap (wiping clean & re applying after a few turns or so).After tapping, I Q-Tipped as nuch grease as I could and then set the pistion at the beginning of compression stroke and sprayed some WD-40 into cyl & cranked engine over a few times to help blow out anything I did not get w/ the wiping.<br /><br />Worked great, just use a decent amount of pressure on the tap, keep it straight and clean the threads real good to make sure the sleeve locking compound works right.<br /><br />After this season, yes, I will pull the head and check things out (possible replace the head if/when I get a parts motor)<br /><br />I heard Samual Adams has a cure for<br />"bolt snap-a-phobia" I will give it a try. <br /><br />Once again, much thanks for the ideas.......
