Hi this is my first time on this forum, need help
I have a 1988 maxuum boat with 125 HP force engine. rebuilt the engine with all new parts accept the pistons, they were fine.
I was hoping to at least 140 to 150 PSI on compression but could only get 100 all across. so i pulled the head gasket and replaced with new also checked to see if any of the new rings were broken by checking the cylinder walls. all good.
adjusted the timing, new plugs backed adle screw all the to seat and then 1/14 turn open. new poissen power reeds,
very hard to start the engine and when it starts it misfires and coughes with white smoke from the top. when i get it
running it runs for may be 2 minutes and then is starts doing the same.
any help i would appreciate.
thanks
jamal
thanks
jamal
