intrepid
- Oct 30, 2002
- 50
maybe some help with my start up problem
i have a 1995 capri 1952 model cuddy 3 liter merc engine i/o -- commander 3000 control
that has a cold start problem
usually happens after not starting the boat for at least a month or 3 weeks.
When the engine is cold it will not start even after priming
(moving the handle back and forth multiple times)
all the time.
press in the neutral switch move level forward all the way then back and forward again about 1/3 and try to turn over.
most times the entire electrical systems acts as if it were dead and only the feul / other guages indicate.
Then it does fire After a few tries , ---When it does start
the engine seems to run on 2 or 3 cylinders shaking violently at first till it warms up , then its ok
once started and warm it restarts no problem
neutral safety switch bad ? ?? suggestions ?
all the time.
