Hi guys,<br /><br />I need your help please, on an issue that I can't figure out myself.<br /><br />I sold a 22 pitch four-blade Turbo propeller this fall, but the buyer is not getting the results he expected. Here's the info he gave me:<br /><br />21 foot daycruiser<br />V-hull, kind of like mine in the picture<br />Approx weight is 3600 lbs<br />1999 model 5,7L Mercruiser EFI 290 hp on the shaft<br />Alpha drive Gen II, said to have a ratio of 1.5:1<br /><br />With this prop, he is getting the following performance:<br /><br />WOT at 4800 rpm, 35,7 mph (31 knots)<br />Cruise at 3200 rpm, 29.9 mph (26 knots)<br /><br />The speed is measured with GPS, I think.<br /><br />I figure this to be a slip rate of about 47% ???<br /><br />Wouldn't you have expected this boat to be a lot faster, maybe more like 45-50+ mph?<br /><br />What do you think is wrong here?<br /><br />Is his tachometer off, does the drive maybe have a 2.4 ratio, is the engine not pulling properly, or is there something else wrong?<br /><br />On this setup, what approximate size propeller would you usually run?<br /><br />Please help, as I feel bad for this guy who just spent a lot of money on a new prop (from me...).<br /><br />I've recommended he check the drive ratio, tach and engine performance before he spends more money on another prop. He was thinking he'd buy & try a 24-25 pitch next...
