no genisis urethane ss, not a nason fan. all in what you use. zool you are in the same level as i am. most people wont pay for nason,let alone imron, concept, awl grip, genesis......they want the rustoleum price but awl griplook lol. they dont understand under coat performance or cross linking. imron was ok as long as you dont sand to smooth. i use alot of dimension......sw version of nason. feel its a touch better. have you tried the rustoleum with hardener trick
Genisis is acrylic based, like Concept, Ful-thane, Awlcraft, ect, ect. Though I don't have a problem with Dupont, Basf, SW, ect, I pretty much only Use PPG Concept or Delfleet Evolution, mostly because I keep an abundance of the reducers, surface cleaners, primers on hand, so when I need to paint, I just pick up the paint and catalyst.
I also don't mean to dog the linear aliphatics like Awlgrip, Sterling, ect. Being polyester based, they are generally more abrasion, stain, and chemical resistant than their acrylic sisters. What I do see is a lot of techs and DIYers go about applying them like auto paint, get frustrated, and blame the product. Most SS urethanes and basecoats are applied wet on wet, usually just two coats over epoxy or wash primers. LPU's have a long out of dust time, so u need a sterile environment, and they need a dry tack coat 1st to hang the paint on, then 2-3 semi dry coats, if applied wet, they tend to sag. Then the names Awldrip or Awfulgrip come out
I love rustoleum paint, just not on cars or boats. After spending countless hours and dollars prepping a body or hull, I wont just throw on $20 Alkyd. I use it all the time on shop equiptment, cabinets, ect. I sometimes use a hardener if spraying, but If brushing, I go straight up.
