Gear ratio for 94 bayliner
fat fanny
Re: Gear ratio for 94 bayliner
Need more info! what motor and outdrive? Plus you will get the best info in the i/o forum.
series60
Does anyone know the gear ratio for bayliner year 1994?
Didn't know Bayliners had gears! If you want to ask a question I might suggest giving us a little more to work with. Is it a stern drive - an outboard? What size of engine. Bayliner made several models that year. How about some serial/model numbers. Spend some time here.
Ayuh,.... Welcome Aboard,.... Is this a 17'er, or a 27'er,...??
Gear ratios are determined by motor size, 'n the outdrive it's attached too....
