hankll
- Sep 10, 2006
- 224
Does anybody know how the wiring is hooked up to a gas tank sending unit? I've seen the boat wiring diagram, but that is showing the gauge end. My sending unit on the tank has 2 connectors, not including the mounting screws to the top of the tank. I'm either not getting +12v through the circuit, and the tank, being aluminum, would itself provide the grounding and the other connector would be the signal wire to the gauge, or the sending unit is bad. But it would be helpful if I knew for sure which way the wiring is on the sending unit.
