I've spent hours reading posts on this and other sites trying to find a SAFE, easy way to empty and clean an aluminum gas tank mounted under the floor of a 1993, 17' Boston Whaler Outrage. I see that pumping, syphoning and professional cleaning services were recommended. I'm sure I'll get a lot of comments but I'm really looking for someone that has done this in a SAFE, easy, practical way with the boat sitting on a trailer. I do not want to remove the tank from the boat or take it to a professional service.
I just purchased the used boat and the 1st owner (I'm the 3rd) disconnected the main tank and used a portable plastic tank. The 2nd owner, who I bought the boat from, thought the reason this was done is because the original owner did not want to fill a 30+ gal. tank because his boat use was only occassional and for short durations. The second owner only used the boat a few times and continued to use the portable tank.
From the fuel gauge I'm guessing that there may be 5 gal. +/_ in the tank. I have no idea of knowing how long the gas has been in the tank or if it is contaminated. I'd really like to get as much as possible out of the tank just to be safe.
My Questions:
Since there is a water seperator/filter attached am I worrying for no reason?
Should I just add some gas additive and forget cleaning the tank?
If emptying the tank is recommended - how do I do it?
If I use a pump - What kind?
Where Do I insert the hose?
If syphoning - where do I insert the hose?
Specific information/instructions would really be appreciated!
Thanks
My Questions:
Thanks
