Re: Gas Gauge Connections
thanks Upinsmoke - so not to confuse umfangler, let me see if I can summarize:<br /><br />On a gauge, the L post must be wired to receive power and subsequenty to light the gauge. To do this, you can wire the L post in conjunction with a dashboard switch, thus allowing you to turn the gauge lights on only when you need them. You can also hop a wire from the I post to the L post. This configuration will cause your gauge lights to always be on when the ignition key is turned on. The amount of voltage used by the gauge lights is usually not enough to make "constant lighting" ever a problem.
