Ok guys. I've been doing a lot of research.
I have a G3 v175 angler. I ripped out all the carpet and plywood. There was no rot but it was weathered...Its 13 years old. I decided I'm going to go with AC 5/8 or 3/4.
I'd like to put down vinyl. Nautolex or something similar. Reviews are good and bad on a lot. I will be installing the vinyl with glue and folded over and stapled with stainless steel.. my biggest question is what can I use for sealing the plywood. I'm not going the resin route. Can I deal with rustoleum top coat or bottom coat? Can I use a polyurethane? Can I use Helmans spar? What would you choose? The plywood that was in There had NO COATING on it...
And it sure didn't look like marine either. There was a couple footballs here and there... Thanks for any advice. I also found my leak... Live well hose had a hole in it!!! Assuming that's the only leak.
