almost... almost works...
Delco distributor in a 84 470 motor.
History: I replaced wires, coil, cap, rotor. The ignition was upgraded to Pertronix 2, coil is flamethrower2. Distributor was disassembled and put back together at a speed shop.
With timing set to 5* BTDC at idle it coughs through the carb, especially when cranking. If I retard it about 30* it starts fine, does not cough but idles crappy. If I advance the timing it will cough more but idle faster. It coughs the most at crank.
My theory: I'm thinking timing is being put off by the fly weights not having the proper tension on them. When the motor starts the timing per the light is significantly retarded but then comes to the setting after 15 seconds. What else could mess up a setting? I'm pretty sure I'm not arcing in the cap as its dry and the behavior is consistent with the timing setting changes.
Thoughts? If I'm right, is there a dynamic setting for the Delco Distributor? X many degrees at 1000 RPM, then Y many at 2000 etc?
