Re: Function of Airbox?
Air box is designed to keep water and foreign matter out of the carbs. Also creates some intake air resistance so running without will cause a lean condition. Some boxes also have connections to bearings to drain and reburn scavenged oil. Also helps prevent fires caused by backfire. Running without one is not a good idea. I would check all of the lines again for leaks to find what is soaking your cover, but run with the airbox installed.<br />Good luck
