Re: Full open throttle on compression test??Why
The main reason I check compression at wide open throttle is if your carbs are not exactly syncronized (meaning you have the same vacuum readings on each one), it will give you a slightly different compression reading for each cylinder when checked with the throttle at idle.<br /><br />You eliminate this when you check it at WOT. And, since all manuals I know say check it that way, you can then compare your results to what they publish.
