Milemaker13
- Dec 24, 2006
- 120
I have an in board fuel tank in the fiberglass tri hull. What is the procedure for adding fuel on the trailer? I am used to setting my plastic tanks on the ground for filling. Do I need to worry about grounding?
Also, my engine (165 mercruiser straight six) has a sticker that says to use leaded gas. I used to add lead substitute to the old motor bikes that called for leaded gas. Should I use lead substitute in this engine?
