wavefisher
- Jul 7, 2013
- 14
I need help diagnosing a problem, here are the symptoms. The engine runs fine at lower speeds but won't run full speed. If I slightly choke it the motor runs better but still not quite full speed. While the motor is running the bulb is completely soft, not sure if that is normal. After shutting down I can pump up the bulb, it seems to restart fine. It came on suddenly, I ran from one end of the lake just fine, fished an hour and when trying to return it started doing this. I have a new fuel pump on order and am considering replacing the fuel line and bulb. Any suggestions?
