so the choke coil would be the black round thing on the side of the carb correct?
now for as an experiment, I went ahead and ran a power wire from the purple wire connection on the ignition switch directly to the fuel pump and when the key in turned to the on position you can hear the pump running, and the motor runs perfectly. will this be a problem?
