The fuel pump on my outboard needs to be replaced/rebuilt. The motor is a 2005 Mercury Bigfoot 25, serial number 1B1 84873. I've looked all over, and it appears that Mercury does not stock a diaphram kit any longer, but will sell a pump assembly for ~$90 or an entire fuel pump for ~$140. Iboats has a Sierra diaphram kit available, but the one that pulls up for a 25 is the wrong shape. The fuel pump on my engine is square. Which is the correct Sierra kit for this outboard - is it 18-7817? I'd love to try to replace the diaphrams rather than the entire pump if possible.
Symptoms are hard starting, and will not stay running long. Primer bulb is not filling as it used to. Both the fuel/water separator and under cowling filters were changed, along with the fuel line.
Thanks
Nodima
Thanks
Nodima
