My boat is backfiring. It runs perfect at idle & runs perfect at WOT. Backfires pretty much anywhere in between (especially when I pull back on the throttle a bit). Things I have done so far:
Anyone have a similar problem or suggestions for what I might do next?
My nearest lake is just under 3 hours away so it makes it very difficult to run back & forth for a water test. I would like to do as much as possible between lake trips.
Engine is a 2002 Mercruiser 350MAG MPI
- Replaced plugs
- Cleaned Flame arrestor
- drained tank & refilled with fresh gas
- changed fuel filter (Twice)
- added Lucas injector cleaner
