The hose between the fuel pump and first carburetor is missing on my engine. The "out" connection on the fuel pump seem to be for a 7 mm hose while the connection on the carb is for a 5 mm hose. The shop manual list this hose as one item but does not state any dimension.
Should I go for a "soft" 5-6 mm hose and force it on the fuel pump connector or use som kind og 7-5 mm converting connector.
