I have a 1988 twin mercruiser 3.7lx's with the Rochester quadrajet. I can't get it to over 3000 rpm. I seems to bog down. I've changed the plugs and they were fouled badly after a couple hours. Since this has happened I've rebuilt the carb, changed points, set the dwell, checked the timing, changed wires, changed coil, adjusted the choke, adjusted the idle mixing screws and can't seem to get it to run right. The frustrating part is that earlier in the season it's run perfect then it started fouling plugs and that's when I changed all those things. Is it possible for the points to go bad that quickly? I haven't re checked the points yet but is that something that can change with little time on the new points? Any one had this problem? I am planning on checking it but was wondering if anyone had a similar problem
