I have opened up my lower unit (1989 Evinrude 50HP E50TLCEC), and found that the forward and Pinon gears have some damage (see pics attached). It looks like the previous owner had something happen where the drive shaft backed out and caused the Pinon Gear to not seat as it should, thus causing some scarring to the Pinion itself, as well as the Forward Gear. My question is... The gears still move as they should and the Pinion Gear as well as the forward gear have enough meat left on them to work. as long as there seated properly. These gears are EXTREMELY EXPENSIVE.... is it necessary to replace these gears, or do you think I could continue to use them as they are?
Thanks
Rick
Thanks
Rick
