Ford windstor 351
Bof
Hi iv a ford windsor 351 on l p g at low speed it sounds like got a miss fire but if I open it up its ok any help on this please
Welcome sboard.
Most likely the mis is there at all rpm ranges
Do the basics. Check fuel filter content. Check compression, check spark with a cylinder drop test
Bof
if i bring engine rev to 1200 it seem to be ok ish i can nail the boat and its fine at mo cant get plugs out i dont want to take manner fold of just yet
take a plug socket and a grinder, grind the socket to a taper on the drive end to fit your manifolds. there is a special socket that was sold so you dont have to pull the manifolds
the fact that you can bring the RPM up then nail it says your idle circuit and accelerator pump circuit are probably plugged
Ayuh,.... Welcome Aboard,.... What's this 351 bolted to for a drive,..??
Have ya done any sorta tune up,..??
If not the plugs, how 'bout the points,..?? Distributor cap look Ok,..??
I think Scott is probably right, sounds like it might be a fuel issue,...
The contents of the fuel filter, Might be hidin' some clues,...
